Is there any way for a do-it-yourselfer to test a heater core at home for the sake of expediency using water pressure or air pressure before installing a new heater core on a 68 coupe with A/C?
I don't want to take the time to send to a shop and wait and the last shop spoiled my original 68 radiator so confidence level in repair shops is a bit low.
I have heard that some new cores can leak right out of the box and that it is wise to test before installing and I have everything apart and want to test the new one before I install. I don't know how much pressure is normal for the system and so don't want to use high air pressure and blow it apart. Can I rig something up to test this core before I install it. Only have body on frame so can't hook up heater hoses and run engine as it is out of car at machine shop.
Thank you for any suggestions,
Kurt Bunting # 26406
