Grille Bracket - Rivets - NCRS Discussion Boards
  • John L.
    • 409
    Do the 1/8" aluminum rivets used to attach the mounting brackets to the grille have the raw side peened over like the finished side (i.e. mushroomed, pan headed) or were they squashed flat. The answer will determine -- whether I use a concave rivet setting tool or a flat one ??
    If anyone has any helpful hints regarding these rivets, they sure would be appreciated.
    thanks
    john lolli
  • John L.
    • 409
    The above is for a 1966 car (NM) *NM*
    • Mike M.
      Director Region V
      • August 31, 1994
      • 1463
      Re: Grille Bracket - Rivets: Pan Headed *NM*
      • John L.
        • 409
        Thanks Mike (NM) *NM*
        • Jerry Coia
          I have a similiar issue on a 1963 Roadster. What was Mike's response to the question?
          • John L.
            • 409
            Jerry
            Mike said the riverts were "pan headed" or finished on both sides. The raw side is finished half round as opposed to flat or squashed.
            john lolli
