'66 rear harness - NCRS Discussion Boards
'66 rear harness
  • Chip Levick
    '66 rear harness
    Where does the rear harness (from Lectric Limited) join the dash harness (also from Lectric Limited)? I traced the old rear harness to an area near the antenna - and that was as far as I could feel or see.
  • Peter J.
    • September 30, 1994
    • 586
    Re: '66 rear harness
    Chip, Mine connects behind the dash cluster. Simple plug-in connection attached to horizontal cross brace.Follow your rear harness to the right side kick panel area and you got about 18" to go.
    • Chip Levick
      How does it get from rear to front? Does it run under the carpet? Under the floor? In the frame? When you say right kick panel - is that drivers or passenger side? Mine is a roadster if that is different.
      • Donald O.
        • May 31, 1990
        • 1580
        Chip,
        Its on the drivers side.
        Don
        • John Raggio
          Chip,
          The wires run along the inside of the car on the left side
          of the driver's seat under the carpet. There is a metal
          channel over them that is held in by clips. The antenna
          wire also runs in the same location.
          • Peter J.
            • 586
            Chip, My mistake - Left side (driver's side) take off kick panel & sill plate, pull carpet back and you then can remove the metal wire cover. That will expose the wires you are trying to get to. Be careful with your carpet behind the seats. If it is original it can be fragile.
            • Grant M.
              • August 31, 1995
              • 448
              From where you have traced the harness (near the antenna) it enters the interior through a grommet in the rear bulkhead and then runs over the arch of the wheelwell and then down to the floor where it runs along the driver's side as described by other respondents, under a metal cover.
