1961 Rear Wheel Cylinders - NCRS Discussion Boards
  • Joe D.
    • April 30, 2002
    • 382
    I am looking for two original rear wheel cylinders for my 1961. Does anyone know the part numbers? Thanks, Joe
  • Dale Pearman
    Re: 1961 Rear Wheel Cylinders
    5459917.............left
    5459918.............right
    The GM Parts Book is in error on the left-right issue. The above is factually correct.
    The casting number for these 1 inch diameter Delco parts is 5450649 left and right. It's the machining that determines left or right application.
    NEVER sleeve a C1 brake cylinder with stainless steel which causes undue rubber piston wear. Always use brass.
    Dale Pearman
    • Lonnie Johnson
      Dale,
      When you say sleeving the brake cylinder with SS, are you referencing the wheel cylinders exclusively, or are you including the MC in your statment?
      • Dale Pearman
        Includes MC
        Rubber acting over a long distance on stainless steel is NOT good. Calipers aren't affected since the travel is so short.
        Dale.
        • Geoff C.
          • May 31, 1979
          • 1613
          What about calipers? *NM*
          • Dale Pearman
            Re: What about calipers?
            Stainless sleeves work well with calipers because the pistons move over very short distances.
            Dale.
