C3 oil pressure what's normal - NCRS Discussion Boards
  • Dale P.
    • September 30, 1995
    • 248
    what oil pressure are most of you other big block owners seeing
    at idle
    at high way speeds
    mine reads 30/35 PSI no matter what .. idle or 65 MPH
  • G B.
    • December 1, 1974
    • 1407
    Oil pressure and people
    Who can really say what is normal? Well, here are my thoughts.
    I am suspicious of your gauge. But, if it's reading right, then you do have abnormally low pressure at high speed. Unless you have a 2.7 rear end ratio, or you're driving in desert heat, or you're using 5W-30 oil, or you're running wide main bearing clearances, or...
    I'm used to seeing about 25 - 30 at idle and maybe 40 - 50 at 3,000 rpm after the engine is fully warmed up. That's with a standard oil pump.
    • John Lokay
      Re: C3 oil pressure what's normal
      For my 66' Big Block, with 20-50w oil, about 60 lbs when doing 60 mph and 30 to 40 lbs at idle. When the outside temperture exceeds 85+ degress, the oil pressure at idle will be no less than 20 lbs.
      • Bill Braun 33186
        John,
        Mine's the same. Although it's a C2 I expect the motor designs are similar enough to allow a good comparison.
        Bill 33186
        • Brian Monticello
          Oil pressure ranges
          Here's some info I found on Oil pressure for 1960's corvettes. I know you have a C3 but this may give a general idea of operating ranges.
          _Brian
          Antique Cars Classics Customs Hotrods Leadsleds Roadsters Streetrods Trucks Turbine Car 40 31 Ford 67 Dodge Charger 61 Chrysler Images Specs Pictures Photos Photographs Gifs Jpgs Events Schedule Vendors Forum
          • Eric Fairclough
            Hello, I have a 72 ls5 454 all orginal motor with 71,000 miles on it, runs excellent. If your oil pressure guage does not fluctuate at different rpm's it sounds to me like your oil line to the guage is clogged with some old oil. Here is my readings. Eric
            Idle 35
            highway and normal cruising speeds 52
            full open throttel and getting on it 60
