C1 Tool Name - NCRS Discussion Boards
C1 Tool Name
  • Richard H.
    • March 1, 1985
    • 241
    C1 Tool Name
    What is the name of the tool that is required to remove the bolts holding the grab bar in place? Are there any other similar bolts on the car which require the same tool? Thanks.
  • Bill W.
    • March 1, 1980
    • 2000
    Re: C1 Tool Name
    clutch head screws . yes there are a few different sizes of them used on your car. snap on tools makes them in sockets and screw drivers .I dont know about other tool makers. my set has 6 sizes. Bill
    • Richard H.
      • March 1, 1985
      • 241
      Re: C1 Tool Name
      Thanks for the reply.
      • Ron R.
        • August 31, 1993
        • 159
        Re: C1 Tool Name
        Also found them at Home Depot and Sears, just not as great a selection
        Ron
        23246
        • Gary Bishop
          Re: C1 Tool Name
          I made my own when needed by using bolts of the appropriate size and grinding down 2 sides to fit. Then I used a socket wrench.
          • Richard P.
            • July 31, 1995
            • 57
            Re: C1 Tool Name
            Another source for these bits may be your local Home Improvement Supply Store. Locally a Black and Decker 1/4"hex drive bit is available in both 5/32" and 3/16" sizes. They are described on the blister card as "Clutch Screwdriver Bit Tip". Part #'s are 71-368 for 5/32" and 71-369 for the 3/16". Chase Pitkin ( a regional DYI Store) carries them in the drill bit display area. The advantage of the bit is that it can be driven with a number of different tools depending on the space available.My $.02
