1958 Generator mounted on Left side of engine - NCRS Discussion Boards
  • Jim Albright
    I am restoring a "58 that is a very early production 2nd or 3rd week of October 1957 that has the generator mounted on the Left side of the engine like a '57. All the information that I have found on 1958's show the generator on the right side. The wiring harness appears to be original and never replaced with the voltage regulator mounted on the left also. Could this be correct for a very early production '58 as this was the 398th corvette built for 1958.
    The reason for my question is two fold obvisly for the corectness of this vehicle and secondly and most important to me which is the correct exhaust manifold castings for this '58 would it be the '57 manifolds casting #3733978 Left, and #3733976 Right,since the generator bracket mounting is on the left or the one's I find in every book I've read for 1958 casting #3749965 Left and #3750556 Right. Please respond if anyone knows what would be correct or have run into this left hand generator mounting on a '58 before.
    Jim
  • Dale Pearman
    Re: 1958 Generator mounted on Left side of engine
    This configuration is NOT uncommon on very early 1958 Corvettes.
    Dale.
    • Roy Braatz
      I had two early 58's and they were the same as a 57 even the manafolds
      • Jim Albright
        Thanks for the information Roy I thought it was the same as a '57 but just wanted to confirm this with someone else that had run into this before.
        Thanks Again,
        Jim Albright
        • Leroy Lemmerhirt
          I am restoring an early 58---#7xx ---generator is on the right side, and has the regular 58 exhaust manifolds.
