I bought 4 brake hoses for my 1961. They are much smaller in diamiter then the old ones. Are all the replacement brake hoses like that? Thanks, Joe
C1 BRAKE HOSE
Re: C1 BRAKE HOSE
Joe,
I suspect that my 56 is the same brake layout as your 62, and so, you should only have 3 hoses - one goes from the junction block to each front wheel cylinder and the third goes from the rear of the long brake line that extends down the frame to a junction block on the rear end housing. The replacement hoses I bought were dimensionally the same as the original ones. It sounds like you have the wrong hoses. Good Luck Steve- Top
