Cam Question : 300 HP vs SHP - NCRS Discussion Boards
  • Steve D.
    • February 1, 2002
    • 990
  • Clem Z.
    • January 1, 2006
    • 9427
    Re: Cam Question : 300 HP vs SHP
    the specs i have for the SHP 097 are dur at .050 228 in/230 ex,.382,382 lift, 110 lobe center. the 929 cam dur at .050 195 in/202 ex, lift .390 in/.410 ex, lobe center 112
    • Dale Pearman
      At what point in the cycle does the intake valve close in both cases?
      Dale.
        • 15610
        The actual timing of the Duntov cam (097) is 35-72/76-31 287/287, based on a 1.5 rocker ratio (it's actually 1.37) and .012"/.018" clearance. This is the actual theoretical "seat to seat" timing points - the points where the valve just begins to lift off and set down on the seat, not the current "advertised duration", which is typically the timing at .006"/.006" valve lift at the theoretical rocker ratio and specified clearance.
        Chevrolet cam specs are all over the place, and seem to vary depending on the era of the cam. The Duntov has both more EFFECTIVE duration and much more overlap than the 929 cam.
        If you want to run a mechanical lifter SHP cam go with the LT-1 cam. It has a very similar inlet lobe with just a bit more duration and is phased two degrees later, but the exhaust is much longer and is phased ten degrees earlier. This is to compensate for the small blocks restrictive exhaust ports, and it was developed with the cast iron manifolds, so it's a tough cam to beat for street high performance unless you have headers. The LT-1 cam also has an asymmetric profile to very gently set the valves back on the seats which is easier on the valvetrain than symmetrical cams
        The LT-1 cam was the culmination of 15 years development of high performance cams for small blocks and the results show.
          • 15610
          Re: Cam Question : 300 HP vs SHP PS
          Duntov designed the cam because he calculated he needed 30 more horsepower to reach 150 MPH on the sand at Daytona Beach.
          He knew he couldn't modify the valvetrain, so his theory was to lower acceleration and spread out the duration for more top end power and a higher limiting valvetrain speed.
          It was later referred to by Chevrolet as a "high lift cam", but as you can see from the specs this was a misnomer. From a practical standpoint it had abaout as much lift as the base cam.
          • Dale Pearman
            Are You Sure Duntov Designed and Developed That Ca
            I don't think so!
            Dale.
            • Dale Pearman
              PS
              In a 350 cu. in. small block the Melling C-80P is AWESOME! I prefer it over the LT-1. (wider power band)
              Dale.
              • Clem Z.
                • January 1, 2006
                • 9427
                what point in the cycle does the intake close
                somewhat after it has opened but before the plug fires.
                  • 15610
                  Re: Are You Sure Duntov Designed and Developed Tha
                  So who do you think designed it?
                  • Norris W.
                    • December 1, 1982
                    • 683
                    Isn't this kind of an apples and oranges comparison anyway, with one being hydraulic lifter and the other mechanical? Dale, what is the C80P Melling camshaft? The number's vaguely familiar, but I can't quite place it in my mind. (along with a lot of other things)
                    • Dale Pearman
                      About fifteen guys in the dyno room working under Harry Barr.
                      Dale.
                      • Dale Pearman
                        It's a solid lifter cam tweaked for 350 cu in and boasts a strong bottom end while allowing for 7000 RPM or more on the top. I ran one in a 350 engine in my 1962 driver for about a year with dual AFBs on an Offenhauser 360 degree intake. I used the GM 292 turbo heads mildly reworked and Harlan-Sharp roller rockers.
                        I was VERY happy with the performance of this engine.
                        Dale
                        • Larry M.
                          • December 1, 1986
                          • 541
                          Hi Dale -
                          OK, so what's your preference for more lower rpm torque in a 350: GM's 327/350 cam (or Melling's version) installed 4 degrees advanced, or the C-80P.
                          Larry
