63 headlight motors - NCRS Discussion Boards
63 headlight motors
  • Lyle Hayer
    63 headlight motors
    After taken apart the motors tonight, I found by moving the gear 180 degrees works great. thankx for the tip. Also, what are the two cut aways in the nylon washer for and should they line up to anything. Can't seem to see the purpose. Any recomendations for bearing grease and should the gear housing be packed. Does a clear coat finish deduct points?
    Thankx to all!
  • Bob R.
    • June 30, 2002
    • 1595
    Re: 63 headlight motors
    I used a little lithium grease applied with a brush. Make sure the material you use won't break down the plastic gears. Oil based materials might be harmfull to the plastic.
