If this is your first visit, be sure to
check out the FAQ by clicking the
link above. You must be an NCRS member
before you can post: click the Join NCRS link above to join. To start viewing messages,
select the forum that you want to visit from the selection below.
I have a 79 vette I checked the temp of the car running with a/c on in stop and go traffic. I taped my thermometer to the upper rad hose the reading on the gauge inside the car was over 220 allmost to the red mark. the reading on my thermometer taped to the rad hose was at about 180 degs my question is what do i do to get the problem correctedwhere my gauge inside the car is working correct
You could have a wiring problem, but more than likely you need a new temp sender. The senders GM supplies are notorious for inaccuracy. I'm not sure if the newer cars use the same sender as the pre 70's cars or not. If they do, there are aftermarket replacements which are more accurate. Wells TU5, available at Autozone (and others no doubt) works well in most older cars. Resistance at room temp is about 700 ohms. Again, this info may not be relevant to the newer cars.
We use cookies to deliver our services, and to analyze site activity. We do not share or sell any personal information about our users. For additional details, refer to our Privacy Policy.
By clicking "I AGREE" below, you agree to our Privacy Policy and our personal data processing and cookie practices as described therein. You also acknowledge that this forum may be hosted outside your country and you consent to the collection, storage, and processing of your data in the country where this forum is hosted.
