Stuck Temp Gauge - NCRS Discussion Boards
Stuck Temp Gauge
  • Michael S.
    • May 31, 2002
    • 91
    Stuck Temp Gauge
    My temp gauge is stuck at 150, all temps. Wiring seems fine, no loose connections. How do I test for a bad gauge or sending unit ?
  • ROB DAME MEM# 36211
    Re: Stuck Temp Gauge
    Mike if you ground out the wire that goes to the temp. sender
    the gauge should peg to hot. Rob
    • Jack H.
      • April 1, 1990
      • 9906
      Caution!
      Make above recommedation read: "...ground the temp sending wire MOMENTARILY..."
      You don't want to carry too much current for too long on this branch circuit AND if the gauge was faulty because the movement was 'stuck', you can force an off-scale deflection that's so hard/so strong you CAN kill the gauge....
