C1 Ignition Key - NCRS Discussion Boards
C1 Ignition Key
  • Peter L.
    • May 31, 1983
    • 1930
    Re: The 2 Key System
    Joe - I went back and did some more checking and my information regarding the introduction of the 2 key system for only the '65 Corvette and Cadillac is not correct. The 2 key system was in fact a new feature on all Chevrolet passenger cars in 1965 which corresponded to the ignition switch having 4 positions and the OFF position was LOCKED. Information from '62, '63, and '64 Chevrolet Owners Guides shows the ignition switch with 5 positions having a SWITCH OFF NOT LOCKED position where one could remove the key in the ON position nd move the switch between the OFF and START position without the key. These cars had one key, the octagon head key that operated all locks. So, it sounds like from the information you have there was a 2 key system prior to sometime before 1962 at least for Chevrolet cars with the Corvette being the exception. Pete
    • Calvin M.
      • August 31, 2000
      • 117
      My late 57 has a two-key system, which I believe to be original.
        Re: The 2 Key System - What's The Issue?
        I can't imagine what all the debate is about on this issue - the Owner's Manual (all four editions) makes it pretty clear - "A single key operates all the locks on your Corvette". Believing a given car to be original is pretty shaky ground when the car is 45 years old and you aren't the original owner.
        • James F.
          • December 1, 1985
          • 596
          #19
          John's right. I'm the original (and only) owner of my '56 and the one key that came with the car did everything: start, doors, trunk, glove compartment. Regards,
