62 fuel gauge - NCRS Discussion Boards
62 fuel gauge
  • Todd Pollock
    62 fuel gauge
    After seeing a post earlier I decided to tackle my fuel gauge. I ran a extra ground wire off a fuel sender screw and cleaned the contacts on my tailights along with the ground. The gauge only moves from being off to the empty line. Any other suggestions? Is there a particular screw to run the extra ground of off? Is the something I need to do to reset the system or something? I am not very good at electrical.
    Todd.
  • Tom Murphy 38312
    Re: 62 fuel gauge
    My '60 had the same symptom. The problem was the sending unit - leaky float.
    • Todd Pollock
      Re: 62 fuel gauge
      Thanks Tom. I ahve an extra sending unit so I will try that. I was always told it was electrical. I'll let you know what happens.
      Todd.
      • Todd Pollock
        Re: 62 fuel gauge
        Thanks Tom, that did the trick. Good thing I waited two years to do that. Does any one make a replacement float so the sending unit is still usable?
        • James F.
          • December 1, 1985
          • 596
          Re: 62 fuel gauge
          Todd,
          Classic Chevy (800) 456-1957, $ 11.00. I have no connection with, yada, yada. Regards,
