hi beam-lo beam - NCRS Discussion Boards
hi beam-lo beam
  • Ray G.
    • June 30, 1986
    • 136
    hi beam-lo beam
    Went to check my headlights on my 72 BB coupe yesterday, and the low beams were fine, but when I stepped on the high beam switch the low beam on the passenger side went out. Any thoughts ? Thanks in advance, Ray
  • Donald O.
    • May 31, 1990
    • 1580
    Re: hi beam-lo beam
    Ray,
    Replace the bulb with a new one.
    Don
    • Donald O.
      • May 31, 1990
      • 1580
      Re: hi beam-lo beam PS
      Ray,
      When you switched from low to high beams and the low beam went out, it should, but the high beam filament should have lit up. Since it didn't, it is most likely broken and the only fix is to replace.
      Don
      • Dave S.
        • August 31, 1992
        • 2918
        Re: hi beam-lo beam
        Ray, The low beams have 2 filaments, one of low and a brigher filament for high. Generally they don't burn out at the samr time causing a condition like you have.
        • Ray G.
          • June 30, 1986
          • 136
          Re: hi beam-lo beam
          Thanks guys, I cant believe I forgot that the low beam has two elements, I hope i'ts just the memory that is the first to go............Ray
          • Juliet P.
            • June 30, 1999
            • 349
            Re: hi beam-lo beam
            Also make sure it's not just a bad connection. I had the same symptoms and changed the bulb to a tested known good one only to have the same thing happen. Once I sanded down the connections inside the wiring end both bulbs worked just fine. ~Juliet
            1970 Corvette Registry
            2019 Sebring Orange 8-Spd Coupe (daily driver & autocross) 6k mi.
            1970 Bridgehampton Blue Convertible - Chapter Top Flight 2005 68k mi.
            1965 Coupe (Greg's project No Flight)
            Gone but not forgotten:
            1987 Yellow Convertible 199k mi.
            2002 Yellow Convertible 100k mi.
            2007 Atomic Orange Coupe 140k mi. RIP flood 2015
            2007 Lemans Blue 6-Spd Coupe 34k mi.
