Can't find any mention of this phenom on this board -
When the brake pedal is depressed while the lights are on, one of them goes dead! The brake light works normally when the lights are off, and the tail light works normally when the brakes aren't applied. Turn signals work great. I've got a new wiring harness in the column, new cancelling switch, etc., and everything else works as it should. Could this be a grounding issue? Any ideas appreciated!
Matt
#38234
Matt
#38234
