why clutch head screws - NCRS Discussion Boards
  • Werner R.
    • March 3, 2008
    • 184
    just for curiosity: does anyone know why holley uses clutch head screws to attach the secondary metering block on certain 4160 carburettors [3310-3; 1850-2]? would not a simple phillips head screw do the job?
  • Gerry Proctor
    Re: Don't SCREW with it.
    Most of the time when these oddball (clutch or butterfly head screws) are used it's an anti-tampering issue or a torque issue. But anti-tampering doesn't seem to make sense since I think there is a natural tendancy with a Holley to take the thing apart and twiddle with it. So I'd have to conclude that it is a screw torque issue. These things are on kind of tight and I'd hate to have to either install or remove them with a phillips.
    • Werner R.
      • March 3, 2008
      • 184
      i have done a couple of these with good results, using a dremel grinding wheel to cut a screwdriver to make it kind of "clutch head". that part is ok. i jave had no sign of a fuel leak internally etc.
      i was just wondering why clutch head. i suppose it is a torque issue, but then why not use clutch head on the fuel bowl screws, where it is suggestred to use about 50 ft lbs of torque [i think that is way too much]. i know what you are saying: probably clutch head to allow lots of torque; but there are other screws on the carb that need torque, and they are all filister head. i still have no idea why the clutch head.
      • Clem Z.
        • January 1, 2006
        • 9427
        DO NOT use 50# ft
        believe me the bowl screws are NOT 50#feet of torque. they are 25/30 INCH #s. i have see more warped metering bodies and float bowls since holley went to 5/16" hex head float bolt screws and people use a ratchet on them.
        • Werner R.
          • March 3, 2008
          • 184
          Re: DO NOT use 50# ft
          i completely agree with that. 50 is way, way too much. i have never had a leak with good gaskets and gentle turning.
          • Chuck G.
            • May 31, 1982
            • 2029
            Why Not Buy Clutch Head Screwdrivers?
            Solid axle guys know all about these They're available. I have a set of just about every size clutch head encountered in 53-62 Corvettes. Chuck
              Re: Why Not Buy Clutch Head Screwdrivers?
              I do too, and have clutch bit sockets to match (from Apex) - can't live without 'em if you have a C1
