'69 side louver trim - NCRS Discussion Boards
  • Shannon Burgess
    I've got a set of the chrome side louver trim inserts that I'm considering installing on my '69 coupe. The inserts do not have the inner portions painted as they should be with the aluminum-looking paint. What is the preferred paint to use for a correct appearance? Should I just mask the outer edge of go slightly further into the louver itself?
    Thanks! Shannon
  • Chuck G.
    • May 31, 1982
    • 2029
    Re: '69 side louver trim
    Hi Shannon. I did mine with Argent Silver...the same paint used for rally wheels. Looks identical. I did mask the edges as you described. Chuck
