60 headlight ground location - NCRS Discussion Boards
  • Matt F.
    • June 30, 2002
    • 79
    Not sure where to look for this - the wiring diagram I've got isn't much help in finding the ground location for headlights & horns. Any suggestions?
    thanks
    Matt
  • Mark Malone
    Re: 60 headlight ground location
    Matt,
    The headlight and horn grounds go to the chassis wiring loom which is a common ground that connects to lots of things including the headlight switch etc.
    The grounds from the headlights just connect to the loom plug and the horn grounds are hardwired to the chassis loom as it runs along the front of the hood opening and the other end just connects via an eyelet to the horn mounting bolt.
    I hope that helps, Mark.
    My Vette Page
