I just purchased a 69 400hp roadster with matching numbers. The pad is stamped T1204LQ with the correct sequence number following. The block casting is 3955270 ... with a date code that reads ONV2 or UNV2. The book I have shows this casting as something other than a LQ usage. And the date code does not make any sence.. Does anyone have any idea what may have happened here? The build date on the trim tag is F02...
John
John
