Hello all,
I have had a problem with my charging system. After several hours of investigation, i found several problems and have repaired them. I am now left with turn signals that work wonderfully without parkigng or headlights activated. Once the parking lights are turned on, the turn signals dim and slow down, as well as causing the rear lights to dim and all dimly blink.
Is this going to trace back to the t/s switch, as i have read in several other strings???
I also recently replaced my alt. and battery, which as stated earlier were not charging properly. The problems solved were a cut wire coming from the alt., and cleaning the junction connectors at the firewall to the fuse box. I also cleaned and double checked the connections/grounds to all lights.
Please help
1stSgt. Ski
Please help
1stSgt. Ski
