I'm finding very little info on CE #s and what I do find is basicly the same info. Hope someone can help. My # is hard to read as the hand punch job wasn't done very well.
1969 350 300hp coupe (originally)
3970010
edelbrock manifold
holly carb 600 (I know this is a replacement)
aluminum or alloy valve covers
CE 9A929 7 8
The CE is clear
The first 9 is a partial, no lower curved part of the 9, but it's got to be a 9 in my opion. indicating 1969?
The "A" if an "A" is a partial. Imagine the portion slightly above the horizontal line missing and that's what it looks like. No were have I seen in my research that a "A" would have been used. I did see something mentioned about an inverted V but can find the info on that.
929 is clear
7 - further away from the "group" of #s and looks larger and deeper than the other stamps, like maybe it wasn't done at the same time.
8- last number, again further away but seems to match the other 8 in style
engine runs fine, some grey smoke sometimes when idleing and see smoke in the rear view after quick exceleration. Was thinking about installing a crate engine because of the non matching block. Any help appreciated.
3970010
edelbrock manifold
CE 9A929 7 8
The CE is clear
929 is clear
