I have a question on a harmonic balancer on my 1969 corvette. The car is an 350/300 with an automatic transmission (original engine). The NCRS manual states that I should have a harmonic balancer that is 6" by 1 1/4 inches. My Harmonic balancer is 8" by 1 5/16". Part number (?) 6966 on the harmonic balancer. Possibly corresponding to GM part number 2896966. There is a stamped number of 7704H on the front. The timing cover tab is the correct one as seen in the NCRS manual and it lines up with the harmonic balancer.
Question: is this the original harmonic damper? Should I have the 6" one on the car as stated in the NCRS book. I believe that the timing cover has never been removed but can't garauntee that has not been replaced. So logic would think that if the harmonic balancer was supposed to be the 6" type then the tab would have to be moved inward to accomodate the extra inch that the timing tab needs to be placed in order to get proper alignment.
Thanks for any help on this question.
