9 Leaf Rear Spring Mounting Bolt with King Nut - NCRS Discussion Boards
  • Ray C.
    • June 30, 2001
    • 1132
    I had to cut the two rear leaf spring mounting bolts and need to secure the correct bolt. Need source!
    Thanks!!
    Ray
    Ray Carney
    1961 Sateen Silver 270-HP
    1961 Fawn Beige 315-HP
    Re: 9 Leaf Rear Spring Mounting Bolt with King Nut
    Ray-----
    The end bolts are available under GM #458982. Or, you can purchase the whole kit which includes bolts, rubber cushions, retainers, nuts and cotter pins under GM #14029851. Vendors like Dr. Rebuild can fix you up with any of this stuff, too.
    • Ray C.
      • June 30, 2001
      • 1132
      Thanks Joe!!
      I am finially getting the 65 back together.
      Ray
      Ray Carney
