Drill that muffler! - NCRS Discussion Boards
Drill that muffler!
  • Andries ter Hennepe
    Drill that muffler!
    Dear all,
    just got the new mufflers for our '65 conv. in. This is the third pair in 6 years. They always rust through in the same spot: lower insides of the muffler bodies. Our '99 Grand Cherokee has a hole drilled in its muffler standard from the factory to let condensation out. This works really well. Anyone with experiance in drilling watering holes in their Corvette-mufflers?
    As always:
    thank you in advance,
    Andries ter Hennepe
  • Clem Z.
    • January 1, 2006
    • 9427
    Re: Drill that muffler!
    any car i owned if it did not have a weep hole for the moisture i drilled a 1/8" hole on the lowest output side of the muffler. also if you still have a heat riser valve,it add to the problem because it keeps the exhaust from passing out that muffler till it opens casing it to run colder.
      Well Clem, thats clear then! Thank you for your answer and out comes the drill. Hope this time they (the mufflers) will live longer.
      • Clem Z.
        • January 1, 2006
        • 9427
        correction on drill size
        i drill a 3/32" not 1/8" diameter.
        • Wayne K.
          • December 1, 1999
          • 1030
          Re: correction on drill size
          Clem,
          Due to the angle that the mufflers hang on a C2 shouldn't the hole be drilled in the lowest input end of the muffler ? Water runs better downhill.
          • Clem Z.
            • January 1, 2006
            • 9427
            sounds correct to me as i have only drilled mufflers that were level.
