1961 Oil Quanity - NCRS Discussion Boards
1961 Oil Quanity
  • M W.
    • July 31, 2001
    • 835
    1961 Oil Quanity
    I know this may seem like such a silly question, but I have had the darnest time finding info tell me exactly how much oil to use during routine oil change including filter. My engine has the original oil pan. I assume 5 quartz but would like to know for sure. Thanks, Craig #36551
  • Dale Pearman
    Re: 1961 Oil Quanity
    The Owner's Manual contains such information as does the AIM.
    Dale Prearman
    • M W.
      • July 31, 2001
      • 835
      Dale,
      As always I appreciate a somewhat round about post, but as for the Owner's Manual I found no reference to a total amount. On page 22 it references when and how often, but unless I am totally blind I found no other reference. Thanks
      As for the AIM, I will check it now. Cheers, Craig
      • Dale Pearman
        I just fill my oil till it says,"FULL". I never have measured it. Be sure to fill the oil filter canister with each oil change otherwise you'll have no oil on the mains or rods for an instant or two when you start it up.
        Dale.
        • Jon S.
          • November 1, 1992
          • 202
          Dale;
          I found this easy to do when I had an adapter and screw-on oil filter. However, when I went back to the original oil filter canister, I was unable to fill it without the oil leaking down my arm while tighten the canister bolt down. Whats the secret?
            jon----
            What's the secret? Stick with or go back to the spin-on oil filter conversion. GM didn't go to this system in 1968 because the cannister-style system worked just as well. You can get all of the benefits for your C1 or C2 by going with the conversion. Just before you have the car judged, you can switch to the cannister (it's VERY easy, of course). Then, when the judging is over, go back to the spin-on at the first oil change.
            • Dale Pearman
              1125 gallons through the oil fill tube and 375 gallons in the filter canister.
              That's what the AIM says.
              I think they mean more than 1 Corvette.
              Dale.
              • Dale Pearman
                Don't fill it so full.
                Dale.
                • Dale Pearman
                  Does Six Quarts Ring A Bell? *NM*
                  • Ray C.
                    • June 30, 2001
                    • 1132
                    Hi! Craig
                    When I first purchased my 61 I sent to GM for an informational package and they sent me a 1961 specification booklet free. Information provided: Five quart oil pan less filter.
                    Hope this helps!
                    Ray #36314
                    Ray Carney
                    1961 Sateen Silver 270-HP
                    1961 Fawn Beige 315-HP
                      It's in the "Capacities" section near the back of the Owner's Manual.
                      • Dale Pearman
                        Oil Pan=5, Filter=1. Total=6 *NM*
