C3 Holley date code - NCRS Discussion Boards
C3 Holley date code
  • Dave Kinaan
    C3 Holley date code
    Hi, I have a Holley Carb, in an original GM Parts box. The GM part number on the carb air horn matches the number on the box. The GM part number is 3955205. The Holley number is 4296. From what I have learned, this carb was for a 1969 427 L-88 Corvette. There is another number below the previous two, it is 0506. I was wondering if this could be a date code and if you could tell me what it meant. The carb appears to be NOS. The box is somewhat weathered, but the carb has never been installed and is in new condition. I bought it to use on a big block Mopar, however if it is truly a desirable piece, I will preserve it.
  • Clem Z.
    • January 1, 2006
    • 9427
    Re: C3 Holley date code
    4296 is a L-88 carb. it should have fuel distribution tabs on 2 of the 4 booster nozzles because of the L-88 manifold cut out divider to increase top end HP. these tabs must be removed if you use it on any other type manifold. i have one on the shelf we used on our BB race car
    • Clem Z.
      • January 1, 2006
      • 9427
      PS
      about the date i do not know that type of info. sorry
        Re: PS
        It's a service replacement made on February 19, 1976.
        • Jack layton #896
          0506 is a date code. 4 digit codes were used in the 1970's. 3 digit codes were used in the 1960's. The first three digits, 050, indicate it was built on the
          50th day of the year ending in a 6. Hence 1976. As John pointed out the 50th day was Feb. 19, 1976. The three digit codes break down in a different method. Another story, another day.
          • Dave Kinaan
            Hi All, Thanks very much for the tip and the info on the date code. I appreciate the quick and informational responses.
