1967 Parking Lights - NCRS Discussion Boards
1967 Parking Lights
  • James C.
    • November 1, 2001
    • 137
    1967 Parking Lights
    I am now on the third try at installing a headlight switch that will shut off the parking lights when the headlights are turned on. The original switch would no longer adjust the dash light brightness, so I replaced it with a supposed NOS #179 switch in the original box, I bought from a reputable company. This would not extinguish the parking lights.I bought another switch from Long Island Corvette, and this does not work either. Can someone tell me where to buy the correct headlight switch for a 1967, or can the original be rebuilt. Is there someway to test the switch/circuits BEFORE I install another one. Very, very frustating.Thanks Jim Carmain #37003
    Re: 1967 Parking Lights
    Jim-----
    I'm going to venture a guess here: I believe that headlamp switches are a part that must be DOT-approved. If so, there may be a DOT requirement that such switches NOT extinguish the parking lamps when the headlamps are on. This may apply to SERVICE switches as well as PRODUCTION switches and may be the reason that GM changed the part number and changed the part "along the way". For this reason, it MAY be that no one now makes a switch with the original configuration.
    Switch GM #1995164 MAY be a switch that incorporates the original design, or it may be the first switch to incorporate the later design. I'm not sure at the moment, but I'll be able to check later.
    By the way, if you have any of the original Delco boxes that your new switches were supplied in, does it say "DOT" anywhere on the box?
    • Ralph E.
      • February 1, 2002
      • 905
      It sounds like you may have a 1968 switch. I believe this was posted before and someone noted that in 1968 the lights stayed on. The 1968 switch is very similar. This was posted before. Check the archives.
        Ralph------
        The 68+ switch is a little bit similar to the C2 switch. However, the 68+ switch has a vacuum assembly and vacuum ports attached to the switch for the headlight actuators. So, it is very easy to differentiate from the earlier switch which lacked the vacuum provisions.
        • Ralph E.
          • February 1, 2002
          • 905
          Thanks for correcting me. I believe this was on an earlier post and someone commented about the switch. I should have looked it up
          • Peter L.
            • May 31, 1983
            • 1930
            Jim - The original headlight switch on your '67 should have been a 1995149 contrary to the '67 AIM. The original switch should have 149 stamped on the metal plate opposite the connectors. The 1995179 is the GM replacement, but as Joe mentioned it's not clear that it functions the same and your experience is that it doesn't. I've heard that NAPA has a replacement that functions as the original but I have no experience to confirm. If I can help, give a shout. Pete
            • Craig S.
              • June 30, 1997
              • 2471
              Pete - any clue how a 1995147 GM switch will function? It's in an old pull strib box. Looks the same, but...I know it's not supposedly for a Corvette. Just curious...thx, Craig
              • Peter L.
                • May 31, 1983
                • 1930
                Craig - Parts book says 1995147 is for
                1967 Ser. 10 thru 30 ( exc. D-D)
                Ser. 20-30 (D-D)
                G-10-20
                And you're right they all look alike, but I figure they all don't function alike. Pete
                • Craig S.
                  • June 30, 1997
                  • 2471
                  Thx Pete....a truck switch. I may give it a try and see how it acts sometime. I have it as a spare, bought it on Ebay from a guy who said it was for a vette, but I didn't bother to check the books for the correct part. But, at $14 I am not out much if it doens't work. Thx!....Craig
                  • Peter L.
                    • May 31, 1983
                    • 1930
                    Craig - Good to know you've not got many $$$$$ into it. Interesting on how all parts on eBay are for Corvettes!!!!!!!!!!!!!! Especially, NOS Corvette parts. Thank goodness for the pictures; but it still truely, a let the buyer beware situation. Pete
                    • Craig S.
                      • June 30, 1997
                      • 2471
                      Pete - I normally research better, but I ran into this switch on Ebay about a year ago, 2 minutes before the end, and the price was so attractive, I bit. But, I have sure seen a lot of misrepresented stuff on Ebay....Craig
