Big Block racing camshaft - NCRS Discussion Boards
  • Rex T.
    • December 1, 1984
    • 455
    I have an L-88 engine sitting in my garage that has an aftermarket camshaft that I cannot identify. I have not removed it from the engine because I may want use it, but I would like to know the specs on it. Engraved on the end of the cam are the following numbers:
    D6207 292/304R8 6567
    Nothing else, no name, nothing. The cam has a copper color to it between the lobes and I think it is a roller type cam, sut not sure, as the engine is still completely assembled and I don't want to mess around with it too much until I can identify some particulars. It was built by a well known machine shop in California several years ago, has Carrillo rods, Arias pistons and a Barnes dry sump oil system. Any help that anyone can provide will be greatly appreciated.
    Thanks, Rex #8089
  • Rex T.
    • December 1, 1984
    • 455
    Re: Big Block racing camshaft
    That last number should have been 6568. Thanks, Rex
    • Clem Z.
      • January 1, 2006
      • 9427
      the 292/304 stands for the duration and R stands for roller. best i can do
      • Andrew Meikle
        I suggest that you put a degree wheel on the crank and measure the intake and exhaust with a dial indicator. You should be able to work out exactly what the duration and lift and overlap is. Based on the numbers it sounds like a large cam which would be hard to use on the street. Good luck
        Andrew
        • Scott Marzahl
          Can you simply call the builder and ask him? Have you checked the west coast cam grinder's catalogs like Engle, Isky, Clay Smith and Crower?
