Wax/Polish Problem - NCRS Discussion Boards
Wax/Polish Problem
  • Don Hege
    Wax/Polish Problem
    We seem to have a build up of wax or polish on our lacquer paint and cant seem to buff it all out.Its like and oily residue and after many attempts it just looks cloudy.Is there a good wax/polish remover recommended to strip it down so we can start over?? Thanks
  • Craig S.
    • June 30, 1997
    • 2471
    Re: Wax/Polish Problem
    Major paint jobbers have wax removers to clean residue off before working on paint to eliminate fisheyes when painting....I believe Dupont's is number 3139 or 3939, but each supplier has a product. Just look up and go to one of your local auto paint supply jobbers and they will help you out....Craig
    • Bill W.
      • March 1, 1980
      • 2000
      The 3939 will work ,you can also give it a good wash job with Dawn dishwashing soap. that will get rid of all the wax.. your problem might be the meterial you are using to remove the wax. 3M makes a yellow polishing rag that is great for removing wax & polish. it can also be used to clean your gauge cluster plastic. it will not scratch. works great on black & can be washed. you need 2, they are about &5.00 each .Bill
      • Joe C.
        • August 31, 1999
        • 4598
        Don:
        Use "Prep Sol".
        Joe
        • Everett Ogilvie
          Which poduct is safest for...
          very old, fragile, flaking, chipping, cracking, heat-checked, original laquer? Will any of these wax removers harm the paint? Thanks.
          • Bill W.
            • March 1, 1980
            • 2000
            Re: Which poduct is safest for...
            3939 wont hurt anything.
