My 65 roadster has the stock power antenna with switch on panel below ignition.
The motor appeared to randomly turn on while driving, even with antenna up.
An investigation of the switch reveals a broken, burned(and previously repaired)
housing, and the antenna is frozen. So far I have found no replacement switches available. Has anyone tried replacement switch such as a single power window switch? Any other repair ideas? Thanks.
