my car [1964] has already had the rag joint replaced. the new kit has two bolts and two of what i call "studs" [the fat one and the skinny one]. my two couplers are exactly alike. each has two equal size holes opposite each other, and each has two cut away areas, equal in size and opposite each other. now i think, as for the 2 bolts, if i start from the bottom and go up, i will have: bolt head; semi-lunar washer with flange pointed toward driver; wall of lower coupler; rubber ring; wall of upper coupler; lock washer; nut. how am i doing so far???
now come the two "studs".
why do all kits have two different size studs?? the cut away portions of the couplers are all the same. can someone answer this one??
finally, for the studs, i ought to have the following: nut; lock washer; wall of lower coupler; rubber ring; fat/skinny stud pointed into cut away of upper coupler. is this correct?? i really cannot figure this one out, and am looking for the usual good advice that this board offers.
