The body is off my '65 roadster and I just installed a new exhaust system from Allen's. It was a pleasure to bolt up - no aggravations of any kind.
Achieving the proper center-to-center spacing of the exhaust tips was fairly easy and I expect the tips to be reasonably centered once the body and rear valance panel are re-mated with the chassis.
My question is that the tips are not parallel with the frame rails --they are angled slightly outboard.
Should the tips be parallel with the framerails & centerline of the chassis??
Or do they normally angle slightly outward?
If I need to bend them inboard, I'd much rather deal with it now.
Thanks in advance
Mike
Thanks in advance
Mike
