Jumping Speedometer C3 1977 - NCRS Discussion Boards
  • jim34671
    What would be associated with a jumping speedometer needle.
    Bounces until steady state speed reached..then OK
    It even does so over bumps.
    Drive cables?..Speedo unit itself??
  • Steve Junkersfeld
    Re: Jumping Speedometer C3 1977
    Jim, You didn't indicate if your car has cruise - but my 77 speedometer acted up prior to my cruise transducer going bad. The cruise transducer interupts the cable between the transmission and the speedometer. In the absence of a cruise control, I'd suspect a dragging speedo cable. Good Luck Steve
    • jim34671
      Yes,It's got cruise control but inoperative.
      Both upper/lower cables in place.
      Jim
      • Steve Junkersfeld
        Jim, There are a couple of metal disks in the transducer that transfer the rotation of the cables. My speedometer problems went away when I replaced the transducer. The transducers run $65 - $85 rebuilt. Steve
        • Rich Beauchamp
          For what it's worth, my 82, 24,000 miles, had a similar problem. The cruise control transducer was going bad. Cleaned it up, and it ran about 100 miles, then failed again. Replaced it with a rebuilt one from Volunteer Vette, and it works fine. Also had to replace the little gears in the tranny. Well... actually, the mechanic did all the work, I just paid for it! The transducer was about $85.00, then a couple of cables as well.
          Hope this helps!
