Re: C3/71 DRIVE SHAFT - NCRS Discussion Boards
  • John D.
    • August 31, 2001
    • 280
    I was contemplating new spicer u-joints this winter and while I was at it refinishing the drive and 1/2 shafts. If I bead blast the shafts would I need to have them rebalanced? Any suggestions on where?
  • Craig S.
    • June 30, 1997
    • 2471
    John - first, GM didn't even balance the half shafts since they are short, and rotate substantially slower than the driveshaft. Second, even if they were, bead blasting will to change the balance. It will however, be incorrect finish wise for judging if that matters.....Craig
    • Craig S.
      • June 30, 1997
      • 2471
      I tried to say bead blasting will NOT affect balnace...some how my finger made the NOT a TO...go figure.
