Re: Trouble with my 3794129 manifold - NCRS Discussion Boards
  • Craig S.
    • June 30, 1997
    • 2471
    If it is the center divider, it will affect the low end torque. When GM cut the divider out of the 5069 big block manifold for the L88, the stagger jetted the carb and added enrichment tabs on two of the nozzles in the venturis to balance the mixture correctly...Craig
