I just pulled my engine on a 73 coupe, manual, L48. The bellhousing has two circles cast in. Both have diagonal lines. One circle has nothing while the other has a 2 on one side of the diagonal and a couple of dots on the other side. These dots look like they may have been numbers or letters that haven't filled in during casting. I've owned this car since new and know that the housing has never been replaced.How can you tell the date? it's impossible to tell what those dots are - they haven't been corrodes off either. The casting is actually poor with lots of knit lines and porosity.
This casting has also been damaged, looks like someone put a jack under it during a clutch replacement and pushed some metal through at the bottom. The pieces are all there. Can it be welded or is it easier to get a proper dated one as a replacement?
Steve L
73 coupe since new
Steve L
73 coupe since new
