C4 Trans 700R4 - NCRS Discussion Boards
C4 Trans 700R4
  • Berndt U.
    • January 1, 1999
    • 72
    C4 Trans 700R4
    Hello
    I have a problem with a 700/4. The car drives only forward. When we use R the
    car will remain forward. Same thing in N and Park. We found out that
    the pre. owner drive with a low oirl level. Have any a good Idea.
    Or a good adress to order parts .Will fit a 700/4 Body from a 94 S Blazer
    Thanks for Helb
    Berndt Germany
  • Mike G.
    • April 30, 2001
    • 180
    Re: C4 Trans 700R4
    Just a thought, but did the shift linkage come loose? From your description, it sounds like your shifter moves, but the transmission itself is not shifting.
    • Berndt U.
      • January 1, 1999
      • 72
      Re: C4 Trans 700R4
      Thanks for your mail. But the shifter work well. I can shift in D and the lower gear and the trans shift 1-2-3 but it will also in R go forward.
      I think the lower oil lever will junk the tans.
      Berndt-Germany
