Hi all: Just looked at a '69 coupe basket case which the owner has had for about 5 years. A friend of his had it for 15 years prior to that. It is supposed to be a 427/400. The apparently original engine has been recently rebuilt and is on a stand. Swears his friend never used the car. Serial number (020xx) matches the chassis. Looks real, broach marks are faintly visible. Here's the catch - block casting # is 3916321 and the ID code is 'IM', which is '68 model year stuff. Additionally the 'M' is definately an overstrike. It looks like the original code was ground off. Owner says it had a solid lifter cam, and he changed it to hydraulic. 'IM' is an L36 hydraulic lifter block with 3x2 and 4-speed. The only scenario I could come up with was the factory needed a 427/400 block in '69, took a leftover '68 L36, put 3x2's on it and put it in the car. Is there any history of this sort of thing. He's asking 7k and it is tempting.
Marty McDonough NCRS 2781
