C2-body checking dimensions - NCRS Discussion Boards
  • tony reilly
    Any one out there who worked in the Styling department that might know where I can get my hands on the digitized body dimensions taken from any of the C2 clay models or other mock-ups used back then?
  • Wayne W.
    • April 30, 1982
    • 3605
    Re: C2-body checking dimensions
    I have to ask why you need them?
    • tony reilly
      Hi Wayne-see my profile-since I've been running the 3D solid modeling software (5 years) it seems like nothing is real unless I have it in the computer-out of touch with reality I guess-but it's soooo neat. Also, if I can get the data, I can model it and play with a customizing design I'd like to see the looks of. If you examine how Shinoda blended the Sting Ray rear end on the '61 and imagine the same with the Sting Ray front end while keeping the cove-that's what I think Chevy should have done, largely in the interests of model continuity but also because the cove looks so darn neat!
      • John Daly
        Tony,
        Do you know if digitized data ever even existed for the C2
        body panels? I thought forms taken from the clay models were turned
        into wood models. These wood models and the resulting blueprints were
        the master reference for the body panels,not any type of digital database. .
        John
        • tony reilly
          Hi John- John Hinckley (Snake488@aol.com) responded to my first post on body checking dims like those that are in the 1964 assembly manual. I can't find that post and his response on Oct 16. Anyhow, he was one of the process engineers on the corvette at the time and said they had a book of 800 or so dims that they used to check the initial body builds and then production inspection checked others periodically to verify tooling and processes. He mentioned that the guys in the styling dept did a manual digitization of the clay thus the current post. To his knowledge, that book and other good stuff went in the dumpster when they left St. Lu in 1981.
