I've read the archives and hear what everybody says about the inaccuracy of the gauges/senders. My 66 L79 runs 210-220 around town and about halfway between 210 and yellow on the highway. The previous owner said he used a stem thermometer and the coolant temp was 180 when the gauge said 220. After I had the car I saw an ad from LI Corvette supply that said they had "calibrated" sending units so I put one in. Not much differance. The car shows no signs of running too hot. Today I measured the coolant Temp with a stem thermometer for quite a while while the car was hot and idling. It indicated 170 at first then after idling a while went to 180. All this time the gauge said 220. What resistance should put the gauge at center? I'd like to see how far off the gauge is. I understand the curve on the sender is not linear and that the tolerance at the cold end is wider than at the hot end, but somebody must have a test for the gauge. Anybody know where to find these specs?
Rich Giannotti
Rich Giannotti
