Is the front crossmember on a 1961 painted gloss black or is it suppose to be painted the same as the frame? Thanks for the help
C1 FRONT CROSSMENBER
Re: C1 FRONT CROSSMENBER
Joe,
The front crossmember was painted before it was mated to the frame, but I belive the gloss was about the same. The end result however makes the point moot as the entire chassis was painted with the same low grade gloss paint at the end of assemblly, just before body drop.
Regards, John McGraw- Top
The totally assembled front crossmember (less grease fittings) was delivered from Detroit Gear & Axle to St. Louis painted medium gloss black. The high gloss asphaltic mastic black out was applied at St. Louis to the completed chassis.
Dale.- Top
