In removing the clock from the console plate does one turn it right or left, in (toward passenger compartment) or out? Thanks.
C1 Clock Removal from Console Plate
Tags: None
- Top
Re: C1 Clock Removal from Console Plate
Push or pull the clock toward the engine to compress the spring, then twist counterclockwise facing the clock (toward the driver). The clock comes out toward the passenger compartment. If it's been in there a while, it may be difficult to push and turn. In that case, access it fron behind the dash where you can get a better grip.- Top
