I have a original expansion tank on my 1965, it is in need of repair, the ends of the tubes have holes in it and someone tryed filling a hole in the side with epoxy which still holds but looks bad. Is it worth trying to restore it and if so where would I take it? Or should I buy a new one with the proper date code if I can get it. The date code is 64M. Thanks for your input.
C2 Expansion Tank
Re: C2 Expansion Tank
Jim-----
At this point, I really think that your existing expansion tank is probably beyond "it's useful life". I think that you could put a lot of effort into it and you still won't end up with a cosmetically acceptable unit.
So, I think that your best plan is to obtain a DeWitts reproduction which has been dated-coded to match your existing tank. Such reproductions are available through vendors like Dr. Rebuild or directly from DeWitts. I suggest both alternatives since, sometimes, if you are purchasing several parts, it's convenient and more economical, shipping-wise, to get it all from a "one-source" vendor.In Appreciation of John Hinckley- Top
