BackUp lights, Brake indicator Light - NCRS Discussion Boards
  • Al Simmons
    Is the back up lights and the brake indicator light on the dash controlled by a switch located under the center console (C3 - 1976, 4 Speed). and where is the switch to indicate head light up located.
  • Jim T.
    • March 1, 1993
    • 5351
    Re: BackUp lights, Brake indicator Light
    The headlights up control on off switch is located on each headlight. The switches are no longer available from GM but are available from Corvette part venders.
    The back-up switch for car should be mounted on a bracket on the transmission with a metal rod connected to the reverse linkage.
    The brake light switch on the dash for the emergency brake is in the console mounted on the emergency brake bracket.
    The brake light also in the dash also activated when there is a pressure loss between the front and rear braking.
    • Al Simmons
