Ignition Coil - NCRS Discussion Boards
Ignition Coil
  • John Lokay
    Ignition Coil
    Just wanted to confirm that the ignition coil in my 1966 L 72 engine (425 hp) is correctly hooked up. I have the white wire attached to the positive side of the coil and the black wire to the negative side. Is this correct? Also, what results if the wires are crossed? Thanks
    Re: Ignition Coil
    John -
    That's the correct hookup based on the K66 wiring schematic I have.
    • Craig S.
      • June 30, 1997
      • 2471
      Re: Ignition Coil
      John - If you want your own schemeatic of the wiring, go to Dave Fiedlers website. He has them for all the various TI setups you can print out....Craig
      Transistor Ignition Specialty offers transistor ignition amplifiers and the distributors for corvettes produced in the years 1964, 1965, 1966, 1967, 1968, 1969, 1970, and 1971.
