Door Glass Re Assembly Process C2 - NCRS Discussion Boards
  • Keith B.
    • December 1, 1991
    • 397
    I was wondering if there was some form of sequence I need to use when putting the glass and hardware back into my 67 convt. door. The vent window assemblies are out as well as the side glass. The side glass hardware has been left in tact that moves the window up and down. Does the glass go in before I put the vent window assemblies? I don't have the weather strip on the door yet either. Because of that the bracket (rear)that the side window slides in is not in because the weatherstrip holds the top part of the braket. I thought that the door weatherstrip attaches to the vent assembly. I would appreciate any help.
    Keith
    Keith Burmeister
  • Joe C.
    • August 31, 1999
    • 4598
    Re: Door Glass Re Assembly Process C2
    Keith:
    This is the sequence that worked for me, (after a couple false starts), some other pro body/fendermen might add some mods to this:
    1. Window regulator/sector gear ass'y.
    2. Upper door-to-window seal (fuzzies).
    3. Vent window assembly (do not tighten yet).
    4. Upper and lower stops to regulator ass'y.
    5. Insert rear window run into door, do not fasten.
    6. Side glass/upper roller track ass'y.
    7. Lower roller track.
    8. Door main weatherstrip (if previously removed).
    9. Tighten all, as needed, and make all necessary adjustments.
    Joe
