'56 Powerglide - NCRS Discussion Boards
'56 Powerglide
  • Steve Westphal
    '56 Powerglide
    Is the '56 passenger car powerglide the same as the Corvette? I might have an incorrect one now and thought if the passenger car was the same I just may switch over. Thanks!
  • Roy Braatz
    Re: '56 Powerglide
    Yes! but for the torque converter, Corvette uses twice the bolts becouse GM thought the high RPM might couse a leak. But the car converter will work fine.55 -57 CAR not WAGON
    • John M.
      • January 1, 1999
      • 1553
      Re: '56 Powerglide
      Roy,
      Wasn't there a difference in the tail shaft housing as well? It has been several years since I watched your video, but I thought that passenger car tailshaft housings do not have provisions for shifter mounting.
      Regards, John McGraw
      • Roy Braatz
        Re: '56 Powerglide
        Use your old tail shaft that is on the trans you have.
