C2, 65 Steering column assembly to dash, missing p - NCRS Discussion Boards
  • Dave Schenk
  • Joe C.
    • August 31, 1999
    • 4598
    Re: C2, 65 Steering column assembly to dash, missi
    Dave:
    It is not clear what you are referring to, so I will give you the long and short.
    On the underside of the column, there is a black plastic sleeve which covers and protects the column harness. This sleeve pins into the column housing, and fits into a slot on the underside of the dash bezel.
    Between the dash bezel, and the column housing, there is a rubber seal, which is held in place by a spring steel clip.
    Both of these items are available from most of the Corvette specialty parts houses, but I like Long Island Corvette Supply for midyear parts-they have a brochure which is taken directly from the Assembly Manual.
    Joe
