Temp. sending unit for 69 BB - NCRS Discussion Boards
  • Trebor M #25911
    Does the temp. sender use a straight tubular fitting or square fitting that pushes on from the side? I have seen both on 69 cars and mine was missing. On a car with VIN #0700 had the clear tubular type and the sender had a theated tip. Thank you.
    Re: Temp. sending unit for 69 BB
    Trebor----
    As far as I know, all 69s used a "pin" type terminal on the temperature sender. The connector on the green wire from the harness to the sender was a brass, "pin" connector with a "clear" plastic insulator.
    • Trebor M #25911
      Joe,
      Thank you. I was not sure which was correct. I'm just finishing up car and I am trying to make it as correct as possible. T.M
